Code
import requests
import urllib3
urllib3.disable_warnings()
response = requests.get(url, verify=False) # Disable SSL verification
response.raise_for_status() # Raise an error for bad status codes
return response.json()
# Printing the data
uniprot_id = "P38484"
display_uniprot_data(data)UniProt ID: P38484
Protein Name: Interferon gamma receptor 2
Organism: Homo sapiens
Function: Associates with IFNGR1 to form a receptor for the cytokine interferon gamma (IFNG) (PubMed:7615558, PubMed:7673114, PubMed:8124716). Ligand binding stimulates activation of the JAK/STAT signaling pathway (PubMed:15356148, PubMed:7673114, PubMed:8124716). Required for signal transduction in contrast to other receptor subunit responsible for ligand binding (PubMed:7673114)
