Code
import requests
import urllib3
urllib3.disable_warnings()
= f"https://rest.uniprot.org/uniprotkb/{uniprot_id}.json"
url = requests.get(url, verify=False) # Disable SSL verification
response # Raise an error for bad status codes
response.raise_for_status() return response.json()
= data.get('primaryAccession', 'N/A')
primary_accession = data.get('proteinDescription', {}).get('recommendedName', {}).get('fullName', {}).get('value', 'N/A')
protein_name = data.get('gene', [{'geneName': {'value': 'N/A'}}])[0]['geneName']['value']
gene_name = data.get('organism', {}).get('scientificName', 'N/A')
organism
= next((comment for comment in data.get('comments', []) if comment['commentType'] == "FUNCTION"), None)
function_comment = function_comment['texts'][0]['value'] if function_comment else 'N/A'
function
# Printing the data
= "P09958"
uniprot_id = fetch_uniprot_data(uniprot_id)
data display_uniprot_data(data)
UniProt ID: P09958
Protein Name: Furin
Organism: Homo sapiens
Function: Ubiquitous endoprotease within constitutive secretory pathways capable of cleavage at the RX(K/R)R consensus motif (PubMed:11799113, PubMed:1629222, PubMed:1713771, PubMed:2251280, PubMed:24666235, PubMed:25974265, PubMed:7592877, PubMed:7690548, PubMed:9130696). Mediates processing of TGFB1, an essential step in TGF-beta-1 activation (PubMed:7737999). Converts through proteolytic cleavage the non-functional Brain natriuretic factor prohormone into its active hormone BNP(1-32) (PubMed:20489134, PubMed:21763278). By mediating processing of accessory subunit ATP6AP1/Ac45 of the V-ATPase, regulates the acidification of dense-core secretory granules in islets of Langerhans cells (By similarity)
