SURFACE-Bind
  • Home
  • Analysis
  • Protein Families
    • Enzymes
    • Receptors
    • Transporters
    • Miscellaneous
    • Unclassified
    • Unmatched
  • About
  1. Hydrolases
  2. P23276
  • Hydrolases
    • O14672
    • O43184
    • O43506
    • O75077
    • O75078
    • O75355
    • O75976
    • P08473
    • P08842
    • P09848
    • P09958
    • P11117
    • P12821
    • P14384
    • P15144
    • P16444
    • P21589
    • P22413
    • P23276
    • P28907
    • P38567
    • P42892
    • P49961
    • P50281
    • P51512
    • P56817
    • P61567
    • P78325
    • P78536
    • P78562
    • P98073
    • Q8IU80
    • Q8TC27
    • Q9BYE2
    • Q9BZ11
    • Q9BZG2
    • Q9H2U9
    • Q9H3S3
    • Q9H4A9
    • Q9H4B8
    • Q9H8J5
    • Q9H013
    • Q9HA72
    • Q9P0K1
    • Q9UEF7
    • Q9UIQ6
    • Q9UJA9
    • Q9UK23
    • Q9UKF2
    • Q9UKF5
    • Q9UKJ8
    • Q9UKQ2
    • Q9UKU6
    • Q9UL52
    • Q9Y3Q7
    • Q9Y5Q5
    • Q9Y5Z0
    • Q9Y6X5
    • Q495T6
    • Q04609
    • Q07075
    • Q13443
    • Q13444
    • Q16819
    • Q16820
    • Q99965
  • Lyases
    • O43306
    • O43570
    • O60266
    • O60503
    • O95622
    • P22748
    • P51828
    • Q9ULX7
    • Q08462
  • Oxidoreductases
    • O00391
    • P04839
    • P14679
    • P19021
    • Q6ZRP7
    • Q9NPH5
    • Q9NRD8
    • Q9NRD9
  • Transferases
    • P0C7U3
    • P04843
    • P52961
    • Q8TCJ2
    • Q8WUD6
    • Q9C0B5
    • Q9H8X9
    • Q13508
    • Q16880
  • Isomerases
    • P40126
    • Q96JJ7
    • Q15125
  • Multiple_functions
    • O60235
    • P07202
    • Q86T26
  • Enzymes
On this page
  • General information
  • AlphaFold model
  • Surface representation - binding sites
  • All detected seeds aligned
  • Seed scores per sites
  • Binding site metrics
  • Binding site sequence composition
  • Download
  1. Hydrolases
  2. P23276
P23276
Author
Hamed Khakzad
Published
August 10, 2024
General information
Code
import requests
import urllib3
urllib3.disable_warnings()
    return response.json()
    # Printing the data
uniprot_id = "P23276"
display_uniprot_data(data)
UniProt ID: P23276
Protein Name: Kell blood group glycoprotein
Organism: Homo sapiens
Function: Zinc endopeptidase with endothelin-3-converting enzyme activity. Cleaves EDN1, EDN2 and EDN3, with a marked preference for EDN3
More information:
AlphaFold model
The computed point cloud for pLDDT > 0.6. Each atom is sampled on average by 10 points.
To see the predicted binding interfaces, you can choose color theme “uncertainty”.
  • Go to the “Controls Panel”
  • Below “Components”, to the right, click on “…”
  • “Set Coloring” by “Atom Property”, and “Uncertainty/Disorder”
Code
import re
import pandas as pd
import os
import plotly.express as px
ID = "P23276"
data_list = []
name_pattern = re.compile(r'name: (\S+)')
score_pattern = re.compile(r'score: (\d+\.\d+)')
desc_dist_score_pattern = re.compile(r'desc_dist_score: (\d+\.\d+)')
directory = f"/Users/hamedkhakzad/Research_EPFL/1_postdoc_project/Surfaceome_web_app/www/Surfaceome_top100_per_site/{ID}_A"
for filename in os.listdir(directory):
    if filename.startswith("output_sorted_") and filename.endswith(".score"):
        filepath = os.path.join(directory, filename)
        with open(filepath, 'r') as file:
            for line in file:
                name_match = name_pattern.search(line)
                score_match = score_pattern.search(line)
                desc_dist_score_match = desc_dist_score_pattern.search(line)
                if name_match and score_match and desc_dist_score_match:
                    name = name_match.group(1)
                    score = float(score_match.group(1))
                    desc_dist_score = float(desc_dist_score_match.group(1))
                    simple_filename = filename.replace("output_sorted_", "").replace(".score", "")
                    data_list.append({
                        'name': name[:-1],
                        'score': score,
                        'desc_dist_score': desc_dist_score,
                        'file': simple_filename
data = pd.DataFrame(data_list)
fig = px.scatter(
    data,
    x='score',
    y='desc_dist_score',
    color='file',
    title='Score vs Desc Dist Score',
    labels={'score': 'Score', 'desc_dist_score': 'Desc Dist Score'},
    hover_data={'name': True}
fig.update_layout(
    legend_title_text='File',
    legend=dict(
        yanchor="top",
        y=0.99,
        xanchor="left",
        x=1.05
fig.show()
Code
import pandas as pd
pd.options.mode.chained_assignment = None
df_total = pd.read_csv('/Users/hamedkhakzad/Research_EPFL/1_postdoc_project/Surfaceome_web_app/www/database/df_flattened.csv')
df_plot = df_total[df_total['acc_flat'] == ID]
df_plot ['Total seeds'] = df_plot.loc[:,['seedss_a','seedss_b']].sum(axis=1)
df_plot.loc[:, ["acc_flat", "main_classs", "sub_classs", "seedss_a", "seedss_b", "areass", "bsss", "hpss"]]
acc_flat main_classs sub_classs seedss_a seedss_b areass bsss hpss
2340 P23276 Enzymes Hydrolases 5 10 2228.487779 210 -12.2
2341 P23276 Enzymes Hydrolases 8 18 929.592418 588 11.2
Code
import math
import matplotlib.pyplot as plt
features = ['seedss_a', 'seedss_b', 'areass', 'hpss']
titles = ['Alpha seeds', 'Beta seeds', 'Area', 'Hydrophobicity']
num_features = len(features)
if len(df_plot) > 8:
    num_rows = 2
    num_cols = 2
else:
    num_rows = 1
    num_cols = 4
fig, axes = plt.subplots(nrows=num_rows, ncols=num_cols, figsize=(9, num_rows * 5))
axes = axes.flatten()
positions = range(1, len(df_plot) + 1)
for i, feature in enumerate(features):
    title = titles[i]
    axes[i].bar(positions, df_plot[feature], color=['blue', 'orange', 'green', 'red', 'purple', 'brown'])
    axes[i].set_title(title, fontsize=13)
    axes[i].set_xticks(positions)
    axes[i].set_xticklabels(df_plot['bsss'], rotation=90)
    axes[i].set_xlabel("Center residues", fontsize=13)
    axes[i].set_ylabel(title, fontsize=13)
for j in range(len(features), len(axes)):
    fig.delaxes(axes[j])
plt.tight_layout()
plt.show()
Code
amino_acid_map = {
    'ALA': 'A', 'ARG': 'R', 'ASN': 'N', 'ASP': 'D', 'CYS': 'C',
    'GLN': 'Q', 'GLU': 'E', 'GLY': 'G', 'HIS': 'H', 'ILE': 'I',
    'LEU': 'L', 'LYS': 'K', 'MET': 'M', 'PHE': 'F', 'PRO': 'P',
    'SER': 'S', 'THR': 'T', 'TRP': 'W', 'TYR': 'Y', 'VAL': 'V'
from collections import Counter
from ast import literal_eval
from matplotlib.gridspec import GridSpec
import warnings
warnings.filterwarnings("ignore", message="Attempting to set identical low and high xlims")
def convert_to_single_letter(aa_list):
    if type(aa_list) == str:
        aa_list = literal_eval(aa_list)
    return [amino_acid_map[aa] for aa in aa_list]
def create_sequence_visualizations(df, max_letters_per_row=20):
    for idx, row in df.iterrows():
        bsss = row['bsss']
        AAss = row['AAss']
        single_letter_sequence = convert_to_single_letter(AAss)
        freq_counter = Counter(single_letter_sequence)
        total_aa = len(single_letter_sequence)
        frequencies = {aa: freq / total_aa for aa, freq in freq_counter.items()}
        cmap = plt.get_cmap('viridis')
        norm = plt.Normalize(0, max(frequencies.values()) if frequencies else 1)
        n_rows = (len(single_letter_sequence) + max_letters_per_row - 1) // max_letters_per_row
        fig = plt.figure(figsize=(max_letters_per_row * 0.6, n_rows * 1.2 + 0.5))
        gs = GridSpec(n_rows + 1, 1, height_ratios=[1] * n_rows + [0.1], hspace=0.3)
        for row_idx in range(n_rows):
            start_idx = row_idx * max_letters_per_row
            end_idx = min((row_idx + 1) * max_letters_per_row, len(single_letter_sequence))
            ax = fig.add_subplot(gs[row_idx, 0])
            ax.set_xlim(0, max_letters_per_row)
            ax.set_ylim(0, 1)
            ax.axis('off')
            for i, aa in enumerate(single_letter_sequence[start_idx:end_idx]):
                freq = frequencies[aa]
                color = cmap(norm(freq))
                ax.text(i + 0.5, 0.5, aa, ha='center', va='center', fontsize=24, color=color, fontweight='bold')
        cbar_ax = fig.add_subplot(gs[-1, 0])
        sm = plt.cm.ScalarMappable(cmap=cmap, norm=norm)
        sm.set_array([])
        cbar = plt.colorbar(sm, cax=cbar_ax, orientation='horizontal')
        cbar.set_label('Frequency', fontsize=12)
        cbar.ax.tick_params(labelsize=12)
        plt.suptitle(f"Center residue {bsss}", fontsize=14)
        plt.subplots_adjust(left=0.1, right=0.9, top=0.9, bottom=0.1)
        plt.show()
create_sequence_visualizations(df_plot)
Download
To download all the seeds and score files for this entry Click Here!
P22413
P28907
