Code
import requests
import urllib3
urllib3.disable_warnings()
= f"https://rest.uniprot.org/uniprotkb/{uniprot_id}.json"
url = requests.get(url, verify=False) # Disable SSL verification
response # Raise an error for bad status codes
response.raise_for_status() return response.json()
= data.get('primaryAccession', 'N/A')
primary_accession = data.get('proteinDescription', {}).get('recommendedName', {}).get('fullName', {}).get('value', 'N/A')
protein_name = data.get('gene', [{'geneName': {'value': 'N/A'}}])[0]['geneName']['value']
gene_name = data.get('organism', {}).get('scientificName', 'N/A')
organism
= next((comment for comment in data.get('comments', []) if comment['commentType'] == "FUNCTION"), None)
function_comment = function_comment['texts'][0]['value'] if function_comment else 'N/A'
function
# Printing the data
= "P49961"
uniprot_id = fetch_uniprot_data(uniprot_id)
data display_uniprot_data(data)
UniProt ID: P49961
Protein Name: Ectonucleoside triphosphate diphosphohydrolase 1
Organism: Homo sapiens
Function: Catalyzes the hydrolysis of both di- and triphosphate nucleotides (NDPs and NTPs) and hydrolyze NTPs to nucleotide monophosphates (NMPs) in two distinct successive phosphate-releasing steps, with NDPs as intermediates and participates in the regulation of extracellular levels of nucleotides (Probable) (PubMed:8529670, PubMed:8626624, PubMed:8955160, PubMed:8996251). By hydrolyzing proinflammatory ATP and platelet-activating ADP to AMP, it blocks platelet aggregation and supports blood flow (PubMed:8955160, PubMed:8996251)
